Distributor question...
For the one who have a distributor that the vacuum is opposed to mine what does the point when you apply vacuum? Go clockwise or counterclockwise?Comment
When I start applying throttle, about 1/3 of the way open, she starts to advance towards to the tdc. I have the three pointer on the case. The mark on the pulley moves towards that, not away from it. I have been messing with my timing as well. I set my timing light to 8 degrees. Started the truck, moved the dizzy until the pulley mark lines up with the tdc mark on the case. The vac advance will only apply under light loads and not wot ( so I understand). Is it possible, and I doubt it, that the dizzy is installed the wrong way? Does the truck run normal otherwise?1969 Series 2a BugeyeComment
emissions
That unfortunately is a distributor used in a poor attempt at meeting the emission requirements of the day. If the rest of the plumbing is missing time for you to get a regular one.1968 battlefield ambulance/camper
1963 Unimog Radio box
1995 LWB RRComment
Lucas 25D distributor, emission controls, and the MG
Sounds like Land Rover was not the only vehicle to suffer from this issue re. the distributor work-around for reduced emissions:
