Hello all,
So some of the accessories that were in my truck before (fog lamps and rear window defroster) were kind of rigged up (fortunately none of the harness was hacked apart to do so). I want to add an extra fuse box and make a neat job of the wiring.
Any tips on how to hook it up, assuming I would like these items to be able to receive power only when the ignition is on. Should I use a heavy gauge wire (w/inline fuse) from the solenoid to one of the 4 fuse box terminals and bridge it across all 4 fuses. Of course, the other side of each fuse would connect to the relay/accessory/switch.
Fuse 1-fog lamps
Fuse 2-rear defrost
Fuse 3/4-L/R heated windscreen (newly added)
Note all will have relays.
Any tips/diagrams appreciated.
Thanks,
Julian
Note: all has been fine electrically now.....heated windscreen may require an alt upgrade in the future, but I do not intend on running everything all at once, so will see...
Fuse 1-fog lamps
Fuse 2-rear defrost
Thanks,
Julian
