What plugs should I be using. I no longer have a generator just a 24 volt alternator if that makes a difference. Thanks
Spark plugs for a 24 volt 2.25
should be the same
12 volt, 24 volt..... the coil will bring the spark up to 30-50,000 volts. Spark plugs should be the same. I have seen some people marketing 24 special plugs but those are usually shielded and have a special attachment to the wires so as to be waterproof and electrically shielded. If you have normal wires , you can have normal plugs.Whence came you my brother ? From the East.... -
Im not really sure if I still have the military set up. It is and exmod and has a 24 volt distributer, coil, coil filter and starter. The generator has been removed and replaced with a 24 volt alternator. It is not currently the military plugs like the ones the ebay listing shows. It is running champion N11YC plugs and I can seem to find anything saying these are the rite plugs for any land rover. What should I be looking for to know if I still have a military set up?Comment
