I just pulled my rocker arm assembly and was wondering if there is any way to get the dowels or bushing out or if anyone knows what size they are... They line up the rocker arm assembly I guess.
Bushing for rocker arm
You will need to make up a press arbor and press them out. The arbor should have a step, with a sharp 90 degree, and a few thous smaller than the bushing, both OD and ID. You can replace them with genuine, or go to any bearing supplier and get oilite bushings. (which may need to reamed to correct ID.
New rockers aren't too expensive, and come with new bushings already installed.
