I have been having brake issues for a while now and today I decided to finally get to the source of my problems when I believe I caused an even bigger problem. So my rear drums had been sticking and last week I took them apart and replaced the shoes, springs and drums. When I tested the pedal it was very sticky and did not return to its original position. Today I thought I would bleed the system and see how that would affect it. I noticed the rear flex line was very worn and when I bled the right rear cylinder dark fluid and bubbles came out. The fluid looked like it had come into contact with old rubber so I immediately thought I would replace the rear flex and see how that changed things. I knew I had a spare flex line so I went to get it and found it to be newly broken at the threaded part. I then came inside to the computer and brought up roversnorth to order a new one when I stopped by the forum. I then found that everyone was saying to use dot4 but not the petroleum based dot4. I had always understood that I was to just simply use dot4. I am almost certain I have used petroleum based dot4, not only today but also 6 months ago when I replaced all of my wheel cylinders and the front two flex hoses. I always thought my best rover buds were being snobs when they would say that they only used "such n such" brake fluid.
How bad did I screw up and could the rubber in my master cylinder be screwed as well? Is that why my pedal won't return to it's resting position? Should I replace my entire braking system when I get a better job??
I'm devastated, should I be?
