Need to retorque my head....
  • TedW
    • 887
    I just had a rebuilt head installed and now need to re-torque the head bolts.
    I have never done this before, but have been told that it is a task I am capable of performing myself. I have a torque wrench and a steady hand.
    Any advice from the group on doing this?
    Thanks in advance - Ted
  • phoenix
    • 144
    90 ft.lbs. work your way in a circle.
    • jac04
      • 1884
      It's easy. I had to re-torque the head on my Turner engine after break-in per their manual. Just use the factory manual torque sequence and specification(s). IIRC., Turner wanted the engine up to temperature when the bolts were re-torqued.
      Make sure to check & adjust the valves after you re-torque the head bolts. The valve clearance will change when you re-torque the bolts.
      • TedW
        • 887
        My green bible says 65; where did you get your figure?
        • LaneRover
          • 1743
          When I re-did my head I was told that the exact amount isn't as important as doing them all the same amount.
          • siii8873
            • 1013
            there is a torquing sequence in green book. It essentially starts in the center and circles it's way out.
            THING 1 - 1973 88 SIII - SOLD
            THING 5 - 1958 109 PU
            THING 6 - 1954 86" HT
            • jac04
              • 1884
              90 ft-lbs sounds high. I say go with the figure in the green manual.
              • 2manykids4a7
                • Nov 2008
                • 75
                Ted - I am about to do this and plan on going with 65 and following the pattern from the green bible (and both my other manuals) which appears to be more of a work from the centre out pattern.
                Community - Am I right that re-torquing is only required if a copper gasket is used?
                Thanks, Steve..
                • jac04
                  • 1884
                  ^^Remember, if you follow the pattern from the green bible, then you should torque the 1/2" head bolts to 65 ft-lbs and the 5/16" rocker shaft bolts to 18 ft-lbs.
                  The manual refers to the fabric type head gasket as a "non-retorque" type versus the copper-asbestos type gasket. However, when it comes to re-torqueing the head gasket, the manual states to do it at normal operating temperature with no mention of not doing it for a "non-retorque" type gasket. Turner wanted the head re-torqued on my engine, and it uses the non-retorque type head gasket.
