What clutch fluid can I use? It says girling castrol...
  • Tasi Autele
    • Oct 2011
    • 47
    The guys at the auto parts store do not have that in stock, nor have they heard of it. Can I use DOT 4?
    Pep Boys stocked Castrol LMA last year, but I didn't see any on the shelf last month. Not sure if they discontinued stocking it, but the computer boy was clueless about what it was here too.
    • bpj911
      • May 2009
      • 128
      fluid
      I just use brake fluid from napa. Only difference between dot 3 and 4 is the boiling point to my knowledge. I don't think castrol lma is anything special nor do i think the land rover requires anything special. Seems like an old wives talke to me.
      • TeriAnn
        • 1087
        NAPA carries Castrol LMA fluid. British Pacific stocks it for LR owners who can not find the fluid locally.
        • Terrys
          • May 2007
          • 1382
          Use any good DOT 3. I wouldn't suggest DOT 4 if you don't know the age or pedigree of the rubber bits in your slave or MC.
          • ThorH
            • May 2011
            • 53
            RN stocks it also.
            1973 SIII RHD 2.25 Petrol
            1992 RRC Hunter
            • TeriAnn
              • 1087
              Castrol LMA is specifically called out in the LR manual. LMA stands for Low Moisture Absorption. It is less hydrophilic than other DOT 4 fluids.
                I think RN is supplying the Land Rover-branded brake juice now (as opposed to Castrol LMA). At least that's what I got the last time I ordered it.
                • TeriAnn
                  • 1087
                  The Land Rover factory manual recommends that all brake system rubber seals be replaced every three years or every 40,000 miles whichever is less whether the system is leaking or not.
                  Why not use DOT4? There is no compatibility issue like there is going from conventional brake fluid to DOT5 silicon fluid.
                  Good to know that RN carries Castrol fluid as well since fewer US auto parts stores are carrying it.
                  • bpj911
                    • May 2009
                    • 128
                    brake fluid
                    All of them taste the same to me.
                    • Tasi Autele
                      • Oct 2011
                      • 47
                      thanks for the replies
                      Thank you everyone. I think I will grab some DOT 3 since I am just trying to get rolling. I plan on having a rolling restoration so I will replace all the seals within the next year anyway. Thoughts?
                      • Terrys
                        • May 2007
                        • 1382
                        I think they stopped using monkey meat for their brake and clutch rubber parts, so that bit can probably be deleted. Seriously, 40K ? What vintage manual is that in? Frankly, I gave up paying attention to LR Manual recommendations about 20 years ago.
                        No reason why not, but it's go to know you got my back. I can't keep straight where the silicone came in, 4 or 5, but in anycase, the clutch system isn't exposed to the heat that the brake system is, so 3 is adequate. One time I was WAY off the beaten path, and used 30 weight motor oil in the clutch to get out. Not only did it work fine, but with every other catastrophe I forgot about the oil for about 6 months.
                        Many years ago, when I bled Green, and Green & Yellow( Being heavily involved with Lotus "cars") I drank the Castrol koolaid. Today, I'm not so sure I think it matters.
                        There 's no question that conventional brake fluid was hydrophilic. The systems are prone to condensation too. What makes a greater difference to me is whether the new fluids are hydroscopic. Simply attracting water will do the nasties to the metalics in the system (brake or clutch) but if it also reacts to the water, then lots of other issues come into play.
                        Better go out and see if I put oil in my 110 clutch.
                        • cedryck
                          • Sep 2010
                          • 836
                          interesting reading
                          So why does most LR literature make a big deal out of using only a certain type of fluid?, from what I'm reading people are putting in different types. Which type will not turn black after 2 months? Inquiring minds want to know.
                          • bpj911
                            • May 2009
                            • 128
                            old
                            These are old trucks with old manuals. A lot has changed. I would put whatever you want in there. Parts wear out and need changing occasionally. Brake parts get changed in regular vehicles all the time. It happens
                            • TedW
                              • 887
                              It is my understanding that the original hydraulic seals were made of a form of (natural?) rubber that would break down if exposed to anything other than Castrol GTLMA type fluid (DOT 4). Silicone (DOT 5) can also be used, but cannot be mixed with any other fluids.
                              However, it appears (from the experience of people on this forum) that the seals of current manufacture allow the use of other fluids without any ill effects.
                              That said, I stick with Castrol GTLMA because I can: it seems to be easy to get around here.
                              Corrections to my comments on fluids are welcomed.
