1964- diesel 88"/Working slowing to replace gaskets and seals on the gearbox and transfer case. intimidated, more or less the process goes slowly, but then comes to a complete stop. HAving repaired a broken stud in the transfer case sump I prepared to move forward......
splitting the gearbox and transfer case requires removing the main shaft bearing housing and then removing the intermediate shaft. This was done late at night in a poorly lit shed (now I regret that I did not immediately closely examine the bearing assembly). As I took the mainshaft bearing assembly out one piece fell- it turned out to be a bushing. No circlip holding it! But that was all that fell. The other components identified in the attached diagram are not there.
Now, last summer I purchased a gearbox/transfer case for $50. It was said to be good, except lacking reverse......So this was a great way to get the missing parts, and indeed they are there.
my original gearbox is # 25191353C/ the spare gearbox is 25276035D
The original seems to rely on a bushing alone/while the spare has a roller bearing.
This raises two questions (the first being most perplexing):
1- neither main bearing housings are a firm wiggle-free fit when mated to the main shaft (just hand fitting them), when I re-join the gearbox and transfer case will tightening down the main shaft bearing housing provide sufficient fixing?
2- Are the mainshaft bearing assemblies interchangable? if so which should I use? looks like the original would work with simple addition of a circlip.
3- Am I missing something here (figuratively or literally)?
I am hoping that the issue is another case of over-thinking and that the insight of memebers will put me back on track.
Thanks.
Thanks.
