I have heard that venting a Santana overdrive will help with the significant leaks I have. My questions are 1) Is this a procedure I can do myself or do I need to hit a transmission repair shop? If I have to go to a shop is this a common thing they have heard of? 2) How do you do it? 3) What are the advantages and disadvantages of doing this? I have looked online and found I need to drill a small hole through the inspection plate on top of the unit. I cannot find what diameter hole or any other guidance.
venting Santana Overdrive
Have you contacted the manufacturer, or reseller of these? I'm guessing you have ruled out seals, etc. Could your fluid be of the wrong type, and thus foaming excessively?64 SIIa 109 all stock
69 SIIa 88 all stock
Old tractors
New Harleys
Old trucksComment
X2 - I did this to my Fairey OD - works swell.Comment
Bobby,
I looked into that very thing all you need to do is drill a hole on the plate and install.............. hey you know what..... in the box here I have one all made up will ship to you!
Any questions just call
RegardsComment
