I was messing around underneath the Rover last night, and at one point I pulled myself up by a tire. And it moved. I tested it by pulling/pushing around the tire (while on the ground), and it wobbles in all directions. Not a ton. Maybe a quarter inch total travel. A little thunking. So I tested the other wheels. Both rears and driver's front do this. I had noticed a little squirreliness on corners this past week.
It may be notable that I had the half shafts out last week to replace the sort one. (though haven't been into the front end yet - hopefully not til spring).
This, I believe is usually a bearing issue. But, I did some searching and came up with little in the way of advice. Looked at the workshop manual, and it seems to indicate either a hub adjusting nut adjustment needed, or a bearing. Don't see what else it could be.
