head light switch question
  • john connelly
    • May 2009
    • 25
    72 series 3 -88 --- head light switch works with parking lights- does not work with headlights. headlights do flash on for a second as i move the switch from- headlight position to Parking light position. any ideas? a bad switch- bad connection. thanks john
    72 series 3 88
    74 bmw r90s
    If you are getting a momentary flash from the headlights as you trun the lights witch to the headlight position, then it sounds like an iffy switch to me.
    My dome instrument/dome light switch likes to do this and it is usually cured by cycling the switch several times to the Dome position (headlight position in your case).
    • artpeck
      • Dec 2009
      • 368
      I would say iffy switch. On my Defender I had the same situation. Contacts were burned from the current load going through the switch. In that case I upgraded the headlamps and installed a relay so that the current load on the switch was minimal. If you are going to change the switch out you might consider doing the same. An easy modification.
      • 73series88
        • Oct 2009
        • 587
        yeah i had to change mine
        went out on the highway at night
        used my hella's to get me to a parts store
        10.00 switch off the shelf and all has been fine since.
        sorry RN.
        aaron
        67 series 2a 88 RHD sold
        88 RRC sold
        60 mga coupe
        • john connelly
          • May 2009
          • 25
          thanks for the replies. going to get a new switch before i take the dash panel apart. like to keep the rig as original as possible -going to try to find an OEM switch. thanks john
          72 series 3 88
          74 bmw r90s
          • cedryck
            • Sep 2010
            • 836
            swithches
            some folks like to replace much used switches with something a little more sturdy, like something from a marine store, they usually are waterproof and a bit better built that some OEM parts.
            • artpeck
              • Dec 2009
              • 368
              Keeping it original was why I installed the relay. Admittedly not fully original if you look very carefully under the hood but fully original inside. Did this after reading many posts of light switches burning out from the current load.
              • john connelly
                • May 2009
                • 25
                i replaced my headlight lamps recently- wonder if the new lamps draw more current and put the strain on the switch. if so the relay would be the answer so i do not have to replace switches. any thoughts. thanks john
                72 series 3 88
                74 bmw r90s
                • mearstrae
                  • Oct 2011
                  • 592
                  You'll probably need a new switch as well as the damage is already done, but adding the relay will protect the new switch.
                  [Keep in mind, Lucas switches have only three positions: Dim -Flicker-Off]
                  '95 R.R. Classic LWB
                  '76 Series III Hybrid 109
                  '70 Rover 3500S
