SerIII bellhousing Torque Specs
  • slorocco
    • 208
    Anyone know the torque specs for the large bolts that hold the series bellhousing to the tranny? Had to swap out the 6cyl bellhousing for a 4cyl one and need to re assemble everything.
  • antichrist
    • Mar 2009
    • 272
    Tight.
    Land Rover didn't provide torque specs for them.
    I'd measure them and torque accordingly.
    Tom Rowe
    62 88 reg
    67 NADA x2
    95 D1 - R380
    95 D90 - R380
    97 D1 - ZF
    • slorocco
      • 208
      Thanks. I won't waste any more time looking. Good and tight will do.
        Just use the standard torque specified for that size/thread pitch bolt:
        EDIT: Sorry it's probably Whitworth if it's on the transmission, right? Here's that chart:
        • slorocco
          • 208
          Never even though about that. Good idea! Thanks.
          • antichrist
            • Mar 2009
            • 272
            Mark,
            Yeah, that's what I meant by "torque appropriately."
            Tom Rowe
            62 88 reg
            67 NADA x2
            95 D1 - R380
            95 D90 - R380
            97 D1 - ZF
              Originally posted by antichrist
              Mark,
              That's what I figured, but I don't think it caught on with everyone...
              • westcoastkevin
                • Jan 2011
                • 162
                Those torque numbers are for the bolts. If the bolts are going into aluminum alloy castings, then the castings strip before the bolts do. Just go with goodandtight.
                  That's a good point....
                  • slorocco
                    • 208
                    I'm a bit slow until hit between the eyes with a 2x4.
                    Good reminder about the steel bolts vs aluminium transmission case. 3 are bolts and nuts, the 4th is threaded into the aluminium case.
                    • antichrist
                      • Mar 2009
                      • 272
                      There's a chart somewhere on the net with torque figures for steel in to threaded aluminum.
                      Tom Rowe
                      62 88 reg
                      67 NADA x2
                      95 D1 - R380
                      95 D90 - R380
                      97 D1 - ZF
                      • deezgunz
                        • Aug 2011
                        • 57
                        I just changed a rear seal and clutch. Good and tight is the way to go. I used the bible torque spec and turned the heads off the bolts. Thankfully when I removed the bell housing there was enough left on the bolt shaft to take it out with vice grips.
                        • antichrist
                          • Mar 2009
                          • 272
                          Sounds like you had weakened bolts or there was a SPOT of using grade 2 bolts at some point.
                          Tom Rowe
                          62 88 reg
                          67 NADA x2
                          95 D1 - R380
                          95 D90 - R380
                          97 D1 - ZF
