Well, I started digging into my "new" S3 and confirmed that the starter is bad. I ordered a new one from Britishstarters but I may have some issues in removing the old one. I noticed that the bolts are heavily rusted and I suspect I'll end up breaking them off in the removal process. Depending on how they snap off, I may need to drill them out. Are there any issues with drilling through the bellhousing and using bolts or do I need to use studs?
S3 Starter bolts/studs
Hello there,
The starter should be held on with studs and nuts, it would be unlikely to break one or both off. I would suggest liberally coating with a product such as Liquid Wrench or similar and let is soak overnight, before removing the nuts.
I have just done the same job on an 88" that has stood outside unused for 10years and the nuts came off without much stress at all.
RN has the studs, # 247145 Stud @ $1.04 each and # RNE396 Nut @ $0.51 each.
