Is this possible...or what I mean to ask "is this wise?" I went with a .03 over bore and read that .04 is the max one should do? I assumed that was due to cooling issues...educate me please.
.5 over bore on 2.25?
this may be a moot point but what units of measurement are you using? he's using millimeters and I'm assuming you're using inches?------------------------------------------------
72 SIII 88
67 SIIA 109
82 SIII Stage 1 V8
-- http://www.youtube.com/barnfind88 -- -
...which is +.020" so it's just fine.
I believe that a half an inch (.5") is slightly more than the factory recommends a cylinder be overbored.
Sometimes, it comes down to what size pistons you can get. Sometimes, some piston sizes are way more expensive than others too.Comment
a friend had a custom set of pistons made up for a project...they cost $600 for the pistons and I think they came with some related parts too.Comment
I think the issue is, "Why the .040 inch max overbore." Usually the engines water jacket sets the max overbore as well as clearance issues within the engine block and on the cylinder head. Also, as mentioned if you did decide to go over to say, .050 inches, pistons would be very costly and run a risk of ruining the engine. You may read of racing engines with wild overbores, but they are specially constucted to allow, in some cases,.100 overbores.
'95 R.R. Classic Lwb
'76 Series III hybrid 109
'70 Rover 3500SComment
I just had my 2.25 rebuilt and had to go 0.60 over. parts are rare and had to come from England. I was tol this is the max and certainly it can be done, as I am driving it, no problems. Part are hard to get, but still avaiable or was 6 months ago. We had to go this large when we found out that the engine was rebuilt once before and bored out to 0.30 or 0.40. I can put you in touch with person should you need this larger size.Comment
You are close but your actual numbers are .060", .030", and .040". 0.60" over is more than half an inch diameter increase on every cylinder. If you went this much you would cut right through the cylinder walls into the water jackets and you would likely be into the adjacent combustion chamber.
I suspect that your engine rebuilder did not go an additional .060 (sixty thousandths) over the first .030 (thirty thousandths) but was a total of 060" over stock.Comment
I was told that if you need to go further than .04 it's better to re-sleeve the cylinders. Not wishing any bad karma on you but it seemed to make sense to me. MY .03's are in already and I'm in the final stages of buttoning it up.I just had my 2.25 rebuilt and had to go 0.60 over. parts are rare and had to come from England. I was tol this is the max and certainly it can be done, as I am driving it, no problems. Part are hard to get, but still avaiable or was 6 months ago. We had to go this large when we found out that the engine was rebuilt once before and bored out to 0.30 or 0.40. I can put you in touch with person should you need this larger size.04 Disco, Gone-Disco died & so did mine
'72 S3 88 - Leakey & SqueakyComment
major overboring reduces the thickness of the cylinder walls which in turn changes the way that heat is transfered around the engine. There is also less wall there to deal with combustion. If the walls are too thin you could actually crack the block or experience increased blowbye due to changes in bore expansion etc. Hence the resleave suggestion.Comment
In regards to my orginal post and 0.60 over, what I meant to say is that it was boared to .60 total over stock. This is the max you can go, I am told from over the pond and geting parts was hard. Right now, I have 600 miles on the rebuild and the 2.25L, with HO head and other goodies, it running as good as it gets. It was running a little hot, but I did add an A/C and evaporator/condensor, restricting air into radiator. We fixed than with a larger aux. fan and everything thing is going well now. Rear axle failed and front wheel drive does not work, but that's another story.Comment
I think you keep meaning to state .060" total over bore. .60 is approaching 5/8 of an inch, way too much for any overbore in anything. When someone says, "It's sixty over." it means sixty thousandths.
'95 R.R. Classic LWB
'76 SeriesIII Hybrid 109
