So everything, except for the seat belts (on order), trim panels, headliner, and bench seats is done!
Fired her up....started right up. Good start. Backed her out of the garage, and drove her round the property where I've been working on her.
The issues:
-Clutch pedal......is there any adjustment to it? All new hydraulics and fluid; bled; no leaks.....a little hard to change gear. Pedal does not feel hard enough.
-Exhaust leak.....between the exhaust manifold and the downpipe.....I remember tightening that sucker well....any thoughts other than retightening?? I was told to put no gasket in between.
-Have to mess around with the linkage....don't think the hand throttle is connected properly, and it might be interfering with the gas pedal as there is not much power (well, is there ever?!).....maybe related to that exhaust leak??
-Screeching sound on acceleration.....it has to be something run by the fan belt.....since the water pump stayed in place and so did the crank pulley, I'll start with the alternator as it was apart.
Positive side---cooling seems good (although maybe only 1/4 mile done!), brakes are good, starts right up, and everything works except the above!
Will dedicate tomorrow to troubleshooting....any tips appreciated!
Julian
The issues:
Julian
(I think from the tstat housing).
