Spin on Oil Adapter
  • siii8873
    • 1013
    Spin on Oil Adapter
    I have read about orientation problems with these. I aquired an "original oil filter adapter" It has FRAM on it? What is the correct orientation of these. I put it in with the filter pointing toward the bulkhead / down a little. Is this correct? Also is there an adapter for installing a pressure sender and pressure switch to the tap on the filter housing?
    I would like to add an oil pressure guage, need to hunt one of them down.
    THING 1 - 1973 88 SIII - SOLD
    THING 5 - 1958 109 PU
    THING 6 - 1954 86" HT
  • Terrys
    • May 2007
    • 1382
    The reason they must be oriented correctly is that many filters have a check valve, or, anti siphon valve. If the adapter were put on backwards and the pressure side then plumbed to the output of the filter, you'd get no oil to the engine. I'm not sure whose adapter you have, but I recall that the Wise Owl one is stamped on the side.
    • TedW
      • 887
      The Wise Owl one has a data plate riveted on that says THIS SIDE UP, or something like that. It also has two threaded ports for senders, etc.
      At least mine does.
      • siii8873
        • 1013
        Mine came in a Land Rover green/white box and has "FRAM" cast into the housing. Was told it was an original NOS adapter.
        • Andrew IIA
          • Feb 2008
          • 327
          Interesting. Photo...photo.. pls
          Andrew
          '63 SIIA 88" SW
          • Jim-ME
            • 1379
            To use a mechanical oil pressure gauge and an electrical warning light out of the same port I used a T fitting from Holden in the UK http://www.holden.co.uk/displayprodu...Gauge+Fittings
            It worked really well.
            Jim
            • Terrys
              • May 2007
              • 1382
              That's interesting, But I've never heard of a Series truck with spin-off oil filter, new from the factory, so I wonder if it was sold by Land Rover, after series production stopped.
              • yorker
                • 1635
                probably this?
                Land Rover UK Forums
                • Terrys
                  • May 2007
                  • 1382
                  Maybe so, but since the OP put this in the Series section, that's what truck I thought he was referring to.
                  • siii8873
                    • 1013
                    pictures of the adaptor below???
                    • yorker
                      • 1635
                      yeah but the do fit on the 2.25 and are a popular upgrade.
                      • yorker
                        • 1635
                        ETC6519 right?
                        • siii8873
                          • 1013
                          Don't think it is that one on the schematic, does not have some of the features. It is on a SIIA 2.25 petrol. I guess just because it's "original" does not mean to a series truck?? I looked at the box it came in and do not see a part number. Hope it's installed correctly.
                          • TeriAnn
                            • 1087
                            Spin on filters came standard on the 2.5L engines, In production from 1985 through 1989 (British army used the 2.5L diesel through 1994).
                            LR part number ETC5347 gets you a new adapter, gasket, oil pressure switch (shown) and a genuine Land Rover spin on oil filter. Or at least that number used to.
                            • Terrys
                              • May 2007
                              • 1382
                              Thanks TA, but we were talking Series trucks, not 2.5 engines
