RRC people:
i searched the forum for window malfunction, but did not find my solution: so her goes: right rear window will not work, motor tests ok, but i suspect the switch either in the rear door or the one on the driver's console. how do i check them for power without shorting-out the circuit!! i just KNOW i will do this if i proceed on my own intuition. i have a wiring diagram, so i know grey/white is (-) adn grey/orange(+). grey/green is ? should i have 12 volts between grey/white and grey/org with key on? or does switch have to be actuated? thanks in advance..
-rob
cape cod
-rob
cape cod
