im leaking oil all over the place i have straight 40 weight oil in there to try and stop the leaks. the leaks i know is the front seal where the timing chain is. the second leak is the oil pan gasket.finally the 3rd leak is between the engine and tranny meet i think its the rear main seal. I have no idea about the engine is it a whole seal or half a seal??? Whats the process that has to be done to change it does the engine have to be taken out? any info will be great
thank you
thank you
