Does anyone know if there is a way to lubricate the heater motor on a 1994 Range Rover Classic without removing the entire dash.
Lubricating heater motor without removing dash
If the left center upper vent (round one on top of dash) is removed it appears that the heater motor can be seen. I believe I can touch the Fresh/recirculation air door servo and Fresh/recirculation air door control valve. Do you think a section can be drilled at that location to spray in lubrication. Do you know of any problems created by breaching the motor boxComment
Well that's one approach. I had not considered that but it's actually a tad easier removing the dash top than going in "face first". Easier that is like doing a hundred belly crunches v. a hundred chin ups, or something like that. You take off the instrument binnacle and undo all the bazillion odd black screws and it pulls out revealing the heater box. Getting the window rubber back where it belongs on reinstall is a bit of a nasty.Comment
