I'm in the process of a heater box rebuild. I've done it before in my prior '89 RR. The current rover is a '90RRC. No big troubles. I'm getting pretty good at doing this time consuming job.
I'm looking for opinions on what foam gasket material to use on the inner doors.
In this rebuild I'm using foam rubber weather stripping from Home Depot. I'm not sure how long it will hold up in the heater box for one reason: the heat. To make the weather stripping hold on better I'm using 3M Super 90 spray adhesive and then attaching the weather stripping.
Any comments about my technique here?
90rrc
rovermechanic.com
90rrc
rovermechanic.com
