I have a 3.5L carb and there are 2 lines going from each carb to the left side of the frame. The engine had been sitting for 3 months and when I fired it up it was fine. The 2nd time, the fuel started ejecting. What is this all about? Any help is greatly appreciated. Thanks
Carbs ejecting fuel
Carbs ejecting fuel
sigpic
Nate B
88 D90 RHD, V8 Present
80 Merc 230GE Petrol in 2011
92 Range Rover - In the 90's
Have to be a little more specific. Hard to tell what you mean sitting here a few hundred miles away. It does sound (If I guess right) that there is a problem with the fuel return lines. My two older cars had this side draught system on their 3.5L engines, now they both have American 4bbl's.
'95 R.R.C. Lwb
'76 Series III Hybrid 109
'70 Rover 3500S -
'95 R.R.C. Lwb
'70 Rover 3500Ssigpic
Nate B
cuis2000@yahoo.comComment
It's pretty easy to convert. I have used both Offenhauser and Edlebrock 4bbl manifolds (I like the Edle better), both with Edlebrock 500cfm carbs, with electric choke. These manifolds are listed for the 215cid Buick engines and sometimes have a notation that they can be used on Rover V-8's. I just rerouted the control cable and fuel line to the single carb. Some folks use the Holley 390cfm carb which is closer to the proper size, but they are pricey. The only downside (?) is an increase in horsepower, and with good tuning mileage won't be decreased very much if at all.
'95 R.R.C. Lwb
'70 Rover 3500SComment
'95 R.R.C. Lwb
Nate B
DIY, fairly easy to tune as different dip rods and jets are available from hotrod shops and on line. Do an Ebay look about you may find bargains on these items. Pretty straight forward American manifold installation.
'95 R.R.C. Lwb
