Hi!
Just purchased my 93 Range Rover 3.9 liter today, and wanted to introduce her and myself. I'm coming from the 'Jeep' world, and this is my first Range Rover.
Found the truck on Craigslist a week ago, and went to see, and buy her this morning. The seller had to jump the truck to get her started (battery was toast), but once running she made the 20+ mile trip without incident. I purchased a new Optima yellow top today, and now she fires right up. Some initial observations/questions from my first few hours:
- Truck starts and turns over, but stalls out. It takes one to two starts before she stays running, but then runs like a champ. Motor is very quiet, has 164k, and it's share of oil leaks. Need a new oil pan gasket for sure.
- Truck drove home without any warning lights appearing on the dash. Once the new battery was installed, I now have a check engine light on. I've done a bit of research and found out I can diagnosis this myself under the right front seat. (Code 17)
- ABS light comes on when starting her up, but goes off once you start moving.
- The hood won't stay down, I had to drive it home with just the safety latch keeping the hood in place. Was worried the entire ride that the hood would fly up and smash the windshield.
Need to fix this ASAP! Looks mechanical, maybe the cable, or latch needs to be freed up?
- Blower for heat doesn't work, but was told by seller that there is heat and it shouldn't be a heater core issue. From what I've read this could be sensor or a bad blower?
- Truck has springs, not bags for suspension. Seller said short wheelbase came with Springs?? Not sure if that's entirely accurate.
- Windows all work, Power seats work, not sure if heat works on seats. Needs a new headliner, and sunroof liner.
- Frame, Body and Interior in great shape for 20yr old vehicle.
- I found a CD Changer in the trunk! No idea if it works, and I couldn't get it to lock back into its home. Regardless, still a wicked cool bonus find!
Finally, do any of you veterans want to share any advice on things I should be looking for as a new owner? Thanks in advance!
I've also posted this introduction on another Forum - Sorry if it's a repeat for some...
-Steve
-Steve
