My 95 lwb had sat for a couple years and it is very hard to shift through the gears. It takes a bit of effort to go from park to first and back. No real "click" into each gear like I am used to. I greased as much of the linkage as i could get to between park and first both under console and under the rover, but it didn't really help. What are my options? Thanks
95 lwb tough to shift between gears
1970 Series IIA 109 EX-MOD
1971 Series IIA 109 EX-MOD
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 GMC 2500 Suburban
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSETags: None -
Probably the best route would be to remove the shifter cable and grease it up with some synthetic grease. A long tedious job, but worth it.Les Parker
Well, the cable runs in a HMMW plastic sleeve so it needs no lubrication. If it's not sliding it's probably rusted and therefore useless. Cables are NLA but good used not a problem. Unless Les or Arthur can pull a NOS one out from under some random pile.Comment
Thanks for the info. Sounds like I need to take the cable out and see what if anything can be done. Does the Disco 1 use the same cable??1970 Series IIA 109 EX-MOD
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSEComment
Took the shifter assembly out of a parts disco 1 I have that worked smoothly. I installed it into my LWB and all is well again. Taking the console apart was the worst part, other than that it came out pretty easy.1970 Series IIA 109 EX-MOD
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSEComment
