Hey everyone! I discovered that the line from my vacuum advance was tucked in under a wiring loom along the left side of the intake and not connected to anything at all! The loose end has a nice little 90 deg. rubber boot on it though.
I'm looking for where it is supposed to be connected and can't find it.
On my truck, there is a vacuum line running from the top of the plennum, right above the butterfly, and routed to the air filter box. All that i've read says that the vacuum advance should be connected to that same spot on the plennum but what i'm seeing here looks like factory connections to the air box.
I'm hoping that sorting this out will help my cold engine rough idle and slight hesitation from stand-still problems.
Thanks so much for all of your help!
Jeff H.
Jeff H.
