my 93 range rover has a nasty kick back in the brake pedal. all lights and pump seem to cycle fine. I took the fuse out on the abs, and still have the same problem. also with the abs fuse in i have a bad pull when applying the brakes. any help would be great.
93 rover brake kick back
Which way is the vehicle "pulling"? The problem could well be a stuck (frozen) caliper.
I would sugesst check all the caliper pistons to make sure that all work correctly.Les Parker
also the pulling is under extrem conditions (like a dog running in front of me) The kick back happens any time i hit the brakes, and after holding the brakes every thing seems fine. (kick back is gone untill next time).Could this be the accumulator ball?Comment
