Hi all,
I've been working on resurrecting one of my '92 RRC's, sadly, it seems my oil pump has lost its prime and I can't get it to pick it back up. (Not so far, anyway).
A complication is that I'm in non-runner mode, at the moment, but when I had it running briefly (~2 minutes), it would not put out the indicator light, even when taken up to ~1500 rpm.
I changed the oil to a light viscosity full synthetic to see if that would help get things flowing again - no help, as a check of the new filter still shows it empty and full of air after quite a few engine cranks (with HT coil lead disconnected to prevent starting. This stuff is about like water at ambient temp, so I had high hopes.
I've removed the distributor and find that the oil pump drive tang turns smoothly and feels normal, turning by hand.
I'm out in the shop right now making a 'pre-oiler' tool so that I can use my drill motor to spin the oil pump drive tang and see if I can determine anything further.
Right now, it looks like my pump gears are worn beyond serviceability. I hate it, as I really don't have time to remove the engine and make that level of repairs, and time and finances (at the moment anyway) prevent getting one of the new short blocks.
She has 180,000 miles on the odometer, and I personally put over 100,000 of those on her, so its hard to remain detached in trying to decide what to do next. She has overall been a darned fine, realiable and economically efficient vehicle.
Jess
Jess
