I just bought a 197-? RRC and it has a body kit that was apparently done by a company in england. It has fiberglass fenders and hood and the fenders are very wide. it is a 4 door 3.5 liter with an LT95. has anyone heard of this?it is either TOR or TRO on a id plate on the rear gate.
TOR range rover classic
if its a four door its NOT a 197* something, thats for sure...unless its a Monteverdi, a swiss company, which tested the 4 door market for LR , The body work was carried out by Fissora from Italy....
50 of them where built
The Solihull's first 4 door arrived in 81
TGComment
so the plate on the back says TOR and it says land rover original also. The truck has a sticker with 1974 on it, but thats not a good thing to judge its age. you say its a 81, because its a 4 door, I feel like I knew that too. if its 1 of 50 should I not cut the body in half?.Comment
A good way to judge the age would be the VIN ..
If its a Monteverdi, its a rare beast and I would get it appraised.
I do not get the point about cutting the body in half
Like I was trying to say, the Montevedri's are the only 4 door Rangies built prior to 81, if it is, then you have a little treasure.
Again plz get me some pics
TGComment
From what I can tell from the pics, its probably an 81, the 82 had a coin tray in the middle of the dash replacing the speaker grill.
the serial decode is quite simple...
SA- Solihull
L - man subdivision
LH - Model code (in our case RAnge rover)
A - 100 inch wheelbase
M - (B- 2 door M-4 door)
V- 3.5 V8 (carb)
2- steering/Tranny code (1-RHD 4 speed,2 -LHD - 4speed, 3- RHD auto, 4 LHD Auto, 7RHD 5 speed, 8 LHD 5 speed)
A (model year code)
Serial number..
With this info you can decode your RR..
Hope this helps
TGComment
thanks I am going to steel the tranny out of it reguardless if it a collectable or not, but I am curious about it, I will have to get the vin and call RNComment
