Surging on Cruise control
  • PaulBarrow
    • 96
    Another annoying little thing is that when the car is on Cruise control at 50 - 60 mph, it surges in pulses. Does anyone know is this something that you just have to live with or is their a cause and cure please?
    Thanks
    Paul
  • PaulBarrow
    • 96
    Does no one have any answers to this? 58 views and no replies? Someone must have some ideas ... please!
    Paul
    • AndrewG
      • Oct 2007
      • 25
      I'm just jealous that you HAVE cruise control. It's not one of the high priorities on my long list of things to fix, but I would love it on my '95 RRC LWB !
      1995 LWB - Daily Driver
      1988 SWB - Bought for parts but it LIVES !
      • jgkmmoore
        • Sep 2008
        • 105
        Paul- Nobody I know has a working cruise control in a Classic, so the experience level with it is pretty much non existent.
        • PaulBarrow
          • 96
          I must just be lucky ... as mine works fine now after I replace the speedo head angle drive! Also found this:
          Surging
          One of the Classic's most irritating habits is a surging of the idle speed when slowing down with closed throttle. This is most evident in lower gears and can be dangerous on steep descents. It usually happens after traveling on dusty roads for a few hours, and the culprit is usually the idle air bypass valve/stepper motor, which needs cleaning. For details see the section on this part above
          on http://www.rangerovers.net/rremedies.html#surging
          Paul
          • 1971Series88
            • Dec 2011
            • 172
            You should also check your vacuum hoses and diaphragm. But like all others mine doesn't work either
            1963 Series IIa 109" 5 door Safari top (SOLD to new home)
            1971 Series IIa 88" Soft top (SOLD to new home)
            1995 RRC - LWB
            2001 Discovery II SE7 (SOLD to new home)
