I have a 92 range rover and it stalls on occasion while driving, not at idle. it's more like a misfire. usually starts up right away by itself while coasting. I am getting an check engine light and ECU code 69, the neutral switch. the neutral switch has been replaced and so have the fuel pump and relays. I have found info on other rover forums that wire harness from neutral switch could have a short. has anyone else had this problem and checked it out. i am having difficulty finding where the neutral switch wire harness comes out topside of the engine.
92 Range Rover stalling (stumbling)
