my 95 lwb RR has the following problem. The dash indicator light tells me I am in high level suspension. From the 3 switches the two outsides are lit (the high and low switches). I have switched the control box under the pass. seat with my spare but is not solving the problem. Any idea's? The car goes upward when I start the engine so the compressor should be OK. Thanks for your help!
air suspension problem
Air Suspension RR 95LWB
The problem occurred all at once without any interference. I have not looked at the Fault code but this will possibly indicate that the system malfunctions. If I push the middle button it lights up too if I push it in. This week I was on my bump stops untill I shut off the engine and restarted the car. Might it be the valve block? Thks for your reply.Comment
