My brake lights stopped working last week. The tails work fine, but when I step on the pedal the brake lights don't come on. I checked all the fuses in the dash and under the driver's seat - all fine. Any ideas where to look next?
Help! no brake lights
There is a connector on the driver's side a-pillar behind the side kick panel that i had corroded and the first wire to go was the brake light power wire might be worth a check!Originally posted by LeslieA) check your brake switch
B) check your grounds
It's one of the two......Luc LR Tech
2011 Range Rover
1961 SII
2017 Toyota Tacoma TRD Off RoadComment
