On my '93 LWB the driver seat will not work. I took the switch apart but it was all clean, etc. Sometimes the seat switch will activate the door mirrors. Is there an easy fix for this or can I remove the memory system and fit a harness from my '87 parts Rover to make the driver seat work. Anyone encountered this before?
Memory Seat
Memory Seat ECU
I am underway trying to get the drivers seat to work on my 94. There is a ecu box mounted to the underneath of the driver's seat (don't get confused with ABS ECU mounted to floor under driver's seat). There is a battery that is soldered to the printed circuit board that corrodes when it fails. My had a resistor and a bunch of the copper traces on the board corroded. I have cleaned up the corrosion, and have ordered a replacement battery and will resolder everything back together to see if it solves the problem. I would imagine most with a LWB will have these sort of problems unless their seat memory ecu had been replaced in the last couple of years.
Andy
