The blower quit working a couple of days ago - I''ve checked the switch and everything is connected and looks ok, and the fuse for the ''fan'' in the center console fuse box is ok. I get nothing from the fan, whether it''s switched to heat or A/C. Does anyone know if there is another fuse or relay that I should check? Is there a fusible link for the fan? Or anything else that might be causing this problem?
Thanks!
Thanks!
PITA to replace.
