Help a RR noob. please
  • xdtac
    • Jan 2009
    • 6
    I just purchased a 1993 COUNTY LWB in good shape. but i pulled on the hood release and the handle along with about an inch of the rod broke smooth off. now can someone guide me in the right direction to the best way to pop the hood with out tearing to much up?
    Thanks alot.
  • CliftonRover
    • Mar 2007
    • 351
    I would start with pulling the grill of if you can. there are tabs that lock the grill in place right under the lip of the hood. you might be able to squeeze a small screw driver under there. then peer up towards the latch and see if ou can actuate the linkage.
    • xdtac
      • Jan 2009
      • 6
      ok i can get the linkage that you release whith your hand released with a screwdriver. but i can not figure out how to get the first"POP" that that releases the hood. any help would be appreciated
      • Les Parker
        • May 2006
        • 2020
        Can you see any of the broken cable on the inside of the drivers footwell?
        A well placed pairs of pliers and you should be able to pull on the broken end to "pop" the bonnet till you can effect a repair.
        • TCongletonRovers
          • Jan 2009
          • 7
          Definately try to gain access to remaining cable from within the cockpit. As Mr. Parker mentioned a well placed pair of vise grips should do the job. cheers! It will be much uglier to work it from the front end.
          Taylor@tcongletonrovers.com
          802-879-0200
          • xdtac
            • Jan 2009
            • 6
            ok guys thanks for the tips but im still having trouble releasing the hood. i can find the cable right behind the mount. my question is it seems extremely hard to get it to budge. is this the correct cable i should be pulling on if so should it be that hard. im just trying to avoid breaking more things.
            thanks guys
            • Ed*
              • 136
              can you post a picture? then we can be sure to tell you if your pulling the right thing
              • xdtac
                • Jan 2009
                • 6
                ok
                • xdtac
                  • Jan 2009
                  • 6
                  • Ed*
                    • 136
                    the picture is a bit dark, but as far as I can tell from looking at my own classic the cable should be in the housing where I put the green arrow (can anyone else confirm?)
                    if you can get to the cable with some vicegrips you should be able to to pull it till it pops
                    sometimes my hood needs to be pushed down and wigled side to side a bit to loosen it up so it pops.
                    • xdtac
                      • Jan 2009
                      • 6
                      ok so pulling right where the arrrow is with vise grips should do it? it seems very hard to pull
                      • CliftonRover
                        • Mar 2007
                        • 351
                        if you haven't pulled the lever before then you might want to spray some PB blaster of liquid wrench on the broken end into the housing and on the latch end through the grill just to try and loosen things up.
                        • Ed*
                          • 136
                          there should be a cable inside the housing that the green arrow points to. you want to pull the cable not the housing.
