i have a 1988 rover classic. i dont get warm air anymore. cooling system is good, holds pressure/no leaks. fan blows strong. problem is i get slightly warm air at best. this is my first rover so i'm still on the upward slope of the learning curve but this one has me stumped. any help or suggestions would be greatly appreciated. thanks.
no heat
Make sure the coolant is plenty full."I can't believe I'm sitting here, completely surrounded by no beer!" -Onslow -
still havent solved this little problem. heres where i'm at; replaced thermostat after flushing system. when i let it sit in the driveway running to burp out as much air from the system as possable i had great heat. but, once i start driving it slowly loses heat. i used a stand alone temp guage just be sure the one in the dash was accurate. engine gets up to temp and stays there fine. full on coolant, no leaks(even double checked oil to make sure i wasnt having a head gasket issue) i can sit there all day long with nice warm air, but once i get moving it dies off. at this point i'm just hoping the weather warms up soon. morning comutes are kinda chilly.
Replace the t-stat again or, test it in a pot of water, sound like its faulty.
When you installed the aftermarket temp gauge and ran the engine up to temp, what was the temp at? and, when you drove what was the temperature when driving?Last edited by kevin-ct; 03-02-2009, 09:07 AM.Kevin
04 XJ8
92 RRC
02 Benz E320
95 RRC (sold 5/10)
72 Series 3 (sold 4/10)
70 Series 2A (sold 6/10)
Morgan +8 (sold 8/09)
90 Jetta (308k miles) (sold 5/11)
72 Triumph Stag (sold 1/08Comment
