1995 Range Rover LWB Accumulator Question
  • WarGetsYouOff
    • Feb 2009
    • 2
    I put on the slightly oversized tires from my 89 classic on my 95 and I am having a problem with the front right brake and it has effectively eaten thru the rotor ruining the rotor and caliper. I get the brake light, I think it is from the worn pads from the wires, and the abs light and traction control are also on until driving over 5 miles +or-. The guy who I bought it from a few months ago said that it needs a new accumulator. I am not sure if this is the solution to the problem I have had a hard brake pedal. The ABS charges just fine and I am hoping that it is the Accumulator because it is the cheapest part to replace in the ABS system. Let me know if you have any thoughts on this.
    PS. I am planning to do the front brakes with brembo cross drilled rotors and will be doing a installation/review post
  • 57loboy
    • Sep 2007
    • 74
    sounds more like a stuck caliper then a bad accumulator...
    '95 RRC LWB (white)
    '95 RRC LWB (Avalon Blue) - sold
    '95 RRC LWB parts truck ready and waiting to donate to the cause...
