I have replaced my rusted rear hatch. Unplugged the harness on the passenger side, installed the new glass and.....well the new hatch is newer/older style. The plug is not even close. SO I unsoldered the 4 wires and attached them to the new wires and reinstalled the plug. BUT non of the wires are the same color, so I do not know what wires go with which. I have a test light and I've grounded it and turned on the rear defronster switch. Non of the wires light the test light. I'm totally baffled. I'm guessing one is for the rear defrost, one for the rear power lock, and the other 2 wires I have no clue. Can anybody shed some light on this for me?
Rear hatch wiring
ok now i cant get the pictures to load
basically i have a black wire and a green with purple wire that go to the 3rd brake light
and an orange wire and pink wire that go to the locking mechanism behind the 3rd light
email me at edrice at gmail if you want me to send you the photos I took or if someone can post them for me
hope this helps
edComment
what year is your truck ed? Mine is 90. I have pink orange, pink black, green purple, and black, but thats only on the truck side. The gate side is different.1990 RRC county
2" OME Lift
2" TODDCO lift
265/75/16 STT Cooper's Discoverer Muds
Custom Bottorf Fabrication Spare tire carrierComment
hey maybe this post will help you
Update: Got it all worked out, only to find that a piece numbered PRC8129, dosent work. It has 2 plugs on either end and a mass in the center. Looks like it is maybe a resister? Not sure. It goes between the car wires and the hatch wires. Its located on the passenger side in the headliner. I need one. Anybody have an ideas?1990 RRC county
2" OME Lift
2" TODDCO lift
