93 lwb. What actuates the fuel door flap lock? Is there a switch somewhere?
Fuel door
There is an electrical actuator (same as used in the doors) mounted above the fuel door. A steel rod drops through the loop on the door. the actuator is accessible from inside below the side window, a rectangular coverplate. Might have to move the CD changer and/or bottle jack out of the way. -
I understand...but what is supposed to actuate that solenoid? The key? How? When you unlock the doors, the fuel door is supposed to unlock too?Originally posted by CJHThere is an electrical actuator (same as used in the doors) mounted above the fuel door. A steel rod drops through the loop on the door. the actuator is accessible from inside below the side window, a rectangular coverplate. Might have to move the CD changer and/or bottle jack out of the way.
Or is there a button somewhere I am not aware of?Comment
