Help wanted
  • dburrows
    • Mar 2009
    • 5
    Help wanted
    i have a 93 rover classic 4.2 grate truck started to run poorly so i gave her a tuneup, plugs wires d-cap rotor flue filter. The flue filter was plugged up good.
    now if it dose start it floods out smells ritchl i replace the O2 sensor flue presser regulator and coolant tempter sensor. i cant not get it to run its bin two month please Help
    Thanks you
  • Joey4420
    • Feb 2009
    • 130
    What plugs did you put in?
    Did you get OEM or aftermarket D-Cap?
    You may have very dirty or clogged open injectors.
    I would also clean the intake.
    Joey
    97 Disco
    10 MCCSm
    Custom Rover Accessories
    Home of the D2 horn buttons
    • Ed*
      • 136
      if you have repeatedly flooded it, the plugs may be soaked and there could be gas in the oil
      may want to check that out once you get it runing
      • dburrows
        • Mar 2009
        • 5
        Thanks I did have aftermarket plugs an d-cap so when i put the coolant tep sen i put oem plugs in. now i cant even get it run she trys but nodda. their in gas in the oil i wanted it to run right before i waste more oil.
        • dburrows
          • Mar 2009
          • 5
          dose any one know some were i can take my rover to get help i put over 800 in parts for this one problem i cant afford to guess any more. i live in hubbardsville ny 13355
          • Joey4420
            • Feb 2009
            • 130
            Not sure up in NY, but if I were to guess and you are smelling fuel, I would say possible worn out injectors... get a fuel pressure gauge and do a leak down test.
            Joey
            97 Disco
            10 MCCSm
