stumbling,stalling,starting ......
long story short, rover started running rough a month ago. stumbling off idle and then spit a code 48. replaced stepper (aftermarket) then would start, if it did had to feather into throttle to rev up. checked intake and fixed a couple of cracked (minor) vaccum lines. woulndt start at all. finally started after unplugging battery and stepper, went to set base idle (per instructions) and wouldt come below 2000rpm with stepper unplugged. tried stepper off parts truck, no change. swapped temp sensor, tps,maf,remove and clean stepper housing,replace gskt,coil,capacitor,fuel pump, all off parts car that was running fine when parked. checked for vaccum leaks with carb cleaner (3 times, lots of spray) bought another brand of stepper and started on 3rd try. today started and let sit in driveway until warm. idle was searching up and down after warm, tried to rev and it stalled. very hard to start back up, if at all. will try again when cooled down. ive heard that aftermarket steppers are sometimes the culprit but i have used these for 6 years and never had a problem on my 92, this was the first with my 91. any ideas?? thanks
on another semi-related note, anyone done a carb conversion on a 3.9?
