i just purchased this vehicle and after about 3 days of driving the ABS pump has started going on and will not go off. so i have not been driving vehicle. replaced relays but no luck it still does it. it does stop if i disconnect the wire at the pump switch or the white plastic connect near the switch. i heard it come on one day when i hit the brakes then it went off, then about a day later it came on and now is not going off. it stayed on when i stopped car and pulled out key so i disconnect wires. now it goes off when i stop car but stays on when i turn on.
so where should i start to fix this?
how much should i expect to spend? no i will not be getting a 1k new pump. used will be all i can and will do at this point.
i hate it when PO's dont tell you everything about vehicle then play dumb. i am sure this was not the first time this went off.
any help would be great, this is my first rr classic. i have been mostly sticking to defenders and older series.
-hawk
-hawk
