Looking at buying a 1991 Range Rover this weekend. Have not seen it yet but can't wait.
1. She tells me that the automatic transmission will not shift into fourth gear.... said the truck runs up and then does not shift... is this a common problem and what is the potential solution? Easy or tough to fix.
2. The other thing I was wondering was which lights should go on in the dash when the power is turned on? All of them or just certain ones?
Thank you in advance!
