the drivers door is stuck closed, (I was cleaning the window motor, it works great, i did not put the door panel on, and it started to rain, so i raised the window, only half way it goes up, so i went insode. the next day the door won't open! i have pulled on the rods, checked the lock, it i ok, but the door just won't open! any ideas how to get it open?
MY DOOR WON"T OPEN!!!!!!
I have found once that the lock rod (the rod that goes to the knob that you push down pull up to lock/unlock the doors) might be out of adjustment (if the door panel is off)
So pull up the rod while you try to open the door
Kevin
04 XJ8
92 RRC
02 Benz E320
95 RRC (sold 5/10)
72 Series 3 (sold 4/10)
70 Series 2A (sold 6/10)
Morgan +8 (sold 8/09)
90 Jetta (308k miles) (sold 5/11)
72 Triumph Stag (sold 1/08 -
STILL WON"T OPEN!!
I tried that kevin, did not work, i work/look at it all day. nothing!the out side opener, nor does the inside opener work! the lock doesn't do anything! can some one help me! can i get the door open, by taking the pin/latch connected to the body of the truck, i am lost here!Comment
Wow, Can you look at the latch and see the lever that works the locking? Can you see if that is fully unlocking?
My friend had this happened to him, he drove over to my house and I found the locking rod sticking, after applying PB Blaster I was able to open the door after working the lever back and forth.
Not saying you are having trouble with this, but I cannot see the latch had broke by you repairing the window motor.
Where are you located?
Kevin
04 XJ8
92 RRC
02 Benz E320
95 RRC (sold 5/10)
72 Triumph Stag (sold 1/08Comment
I don't know
CliftonRover, tried that, Good idea i forgot about that, but nope! Kevin, it all looks like it is working well down there, i am going to tear everything out ( meaning loosing all the screws, and try to remove everything, i can, I can only hope that something else is in the way some how!!!Comment
if you want to take the front hinges off and trash the door I will give you another door if your in the area, what color?Comment
Ok, do i have this right? (my labels on the pic) Also i can take the front decker panel off, (i have to to fix the wipers) i can get to four of the bolts holding the door in, I can go further and remove the fender, so this gets the door bolts off, Does anyone know if i can just slide it out? or does the door lock stricker stop it from coming out? ANy help will be greatly appreciated!Comment
Frick
Fricken frack^##^*@@%$#$$#^#^*^()%^()(_+_~ of course there is a screw in the door behind the door! WHY!!!Comment
On P38’s... If this happens, the only way to open the door is to break it with a long screwdriver and a BFH. The whole latch assembly will break apart then replace the latch. Be carful not to dent the door skin.
Kevin
04 XJ8
92 RRC
02 Benz E320
95 RRC (sold 5/10)
Kevin
04 XJ8
92 RRC
02 Benz E320
95 RRC (sold 5/10)
Thanks Moderator!
yeah i was ranting, i apologize for that, it just seems that everything is dependent on me getting the door open!Comment
