Gasoline smell
  • PaulBarrow
    • 96
    Gasoline smell
    I have a 1989 RRC and after filling it with gas the other day there was a strong smell of gas in the garage the next moring.
    Any ideas whY?
    There were no tell tale signs of gas stains on the floor, nor of dribbles down the outside of any pipes around the fuel tank.
    Paul
  • kevin-ct
    • 309
    You may have over fill it. Does is smell more in the rear or the front of the car? The steel line do rust and starts leaking. You will need to inspect the system from the front to the rear.
    Kevin
    04 XJ8
    92 RRC
    02 Benz E320
    95 RRC (sold 5/10)
    72 Series 3 (sold 4/10)
    70 Series 2A (sold 6/10)
    Morgan +8 (sold 8/09)
    90 Jetta (308k miles) (sold 5/11)
    72 Triumph Stag (sold 1/08
    • pvkd
      • 118
      Same happened to me. I ended up replacing the overflow rubber hose and it fixed the problem (look underneath at the rear drivers side...you will see the issue).
      1971 109 Safari Wagon (1 ton chassis)
      1995 LWB Range Rover Classic
      1997 Defender 90 (repaired at last)
      2001 P38A Range Rover
      • 500mph
        • Mar 2009
        • 4
        I had the same thing happen to my 1990 Classic, smell was REAL strong after fill up...New gas cap fixed it!
        sigpic1990 RRC
