I have a problem with my ABS TC system, my fault display sometimes shows both lights after starting and sometimes it takes a while after driving for a while and sometimes they never light up! I tested for fault codes. It came up 28 so I replaced both relays and still the same problem! Any ideas?
Also I hope I reading the light flashes right!
1 Long flash (3 seconds) , pause, 1 fast flash, pause, 2 Fast flashes, pause, 8 fast flashes, repeat.
Thank You!
Scott
Thank You!
Scott
