Starting issues - 1993 RRC petrol
  • SkinlessFrank
    • Jun 2007
    • 25
    I have a 93 RRC petrol and I am having an issue with what I think is the key tumbler for the ignition. I have to hold the key to get the initial lightup of the dash, then when I turn it over, it starts fine, but if I let go of the key, it shuts off immediately. If I start it, but hold the key in place (so that it doesn't return on it's own, it keeps running.
    Note: I have a replacement startup inhibitor, but have not installed it yet - as I noticed no reverse lights.
    Note 2: I also have had to turn the engine over A LOT to get it to start.
    Note 3: (a lot of notes, isn't it) I have only had the RRC for 9 months, but it has been almost flawless otherwise..
    Any input/suggestions appreciated - thanks,
    Sean
    Sean
    1972 Series III
    1984 Defender 90 [2.5 TD]
    1993 Range Rover
  • Les Parker
    • May 2006
    • 2020
    I think you need this :-
    • SkinlessFrank
      • Jun 2007
      • 25
      Thanks Les! Appreciate the guidance - part ordered...
      - S
      Sean
      1972 Series III
      1993 Range Rover
