Helping out a friend of my brothers with her 1995 Classic with ABS. She has had the car 10 months, quit driving it 1 month ago due to poor brakes. She said the brakes have been poor since she bought it but now they are very very weak. I drove it around a parking lot and it takes 10 feet to stop from 10mph. The brake pedal feels fine, feels like it has good pressure, doesn't travel too far or too little...but you really have to put some force on it to slow down. ABS light is on but she said it goes on/off.
I checked both brake fuses in the fuse box and they are good. She mentioned some noise coming from the brake master area, I didn't hear anything. May be she was hearing the pump running? Should I hear something in that area?
Brake MC has the proper amount of fluid.
Pulled the electrical connections off the pump and they are very clean.
Did a search and learned a little but most people complained of no pedal pressure. One owner solved his problem by cleaning his brake pump ground, I'll go back over and look for that. Also read about a brake relay under the drive seat, I'll check those connections.
I inspected each brake rotor/pads and the front look good but both back rotors are rusted like they haven't had a pad run across them in a year or more.
Hearing all of this do any bells ring? Other then run away from this vehicle and go hug my simple little Series IIa.
pb
pb
