Is it possible for a home mechanic to remove the refrigerant from the ac system safely? Would a set of guages and an empty refigerant tanke be sufficent? I need to remove a bracket holding the A/C Compressor and want to make sure the system isn't pressurized. The car cannot be driven so I have to do it at home.
How to discharge AC System Safely
You'd need a vacuum pump, a refridgerant storage tank and some proper fitted hose to do this job. So, it's not a home mechanics job anymore, unless you do like the "Old Days" and loosen the fittings and let it vent to the atmosphere (which is illegal now...).
'95 R.R. Classic LWB
'76 Series III Hybrid 109
'70 Rover 3500SComment
Hmmmm. That is a problem, if it were the running one you'd be home-free. I don't know if these machines are available for rent, but you never know. Maybe ask around at small repair shops, there may even be a mobile service in your area. If only you could get the bracket off without disconnecting the lines, and leave the compressor for later attention..
