hope some one can point me in the right direction with this
88 range rover classic 3.5 the problem have is the fule pump does not seem to be running when i try to start it , have checked all fuses and the main and fuel pump relays i can hear them both click i thought it was the pump so i removed the tank and replaced the tank to find out it was not bad !
should this system prime the fuel system to build up pressure, i have worked on the earlier injection system as fitted to the english classics what when you moved the flap in the airflow meter the pump would run. kinda lost on this one
anyone have any ideas
