 Black wire: >------------------==
Red wire w/ in line 5amp fuse: >-------//---------==
Hello here is the picture of how it should look like.
instructions how to make it:
*20" of black 18 gauge wire with wire connector in one end and a split flat blade with about 1/4" opening on the other.
*20" of red 18 gauge wire with connector in one end and a split flat blade with about 1/4" opening on the other.
the red wire set has an in line 5 amp fuse per picture.
instructions how to install:
you can either do the wiring "hot" by being careful not to touch anything and ground the wires or disconnect the battery and take the chance to have to reset the radio, windows and sunroof. I did it hot - it does not shock you, it is only 12 volts but if you ground something it may spark and blow a fuse. big deal.
1- Open the fuse box door under the passenger side seat and remove the plastic tree nails that hold the cover surrounding the bottom of the passenger seat exposing the computer modules underneath.
2- Locate the positive battery feed to the right of the fuse box. ( it has a brown and pink wire attached to it).
3- Locate the ground feed wire. ( located farthest to the left of the fuse box - 3rd thick wire by itself).
4-In the big computer module has a bunch of wires and a few color coded plugs. unplug the 2nd green plug from the end. ( this goes to the EAS module)
5- locate the blue and pink wire, clip the blue and pink wire about 2" from the green plug.
6- Using the black wire from the harness you made, connect/crimp the jumper to the blue and pink wire that goes to the green plug side and attach it to the ground side of the fuse box ( make sure to cap off or electrical tape the cut off wire the goes away from the plug into the vehicle that is no longer needed).
7- Locate the blue and white wire, clip the blue and white wire about 2" from the green plug.
8- Using the red wire with the in line fuse you made, connect/crimp the jumper to the blue and white wire that goes to the green plug side and attach it to the positive side of the fuse box ( here is where you need to be careful not to let any wires touch) cap off or electrical tape the wire that goes into the vehicle harness that is no longer needed.
9- re-attach the plug back to the computer and reinstall the shroud under the seat.
10- Under the hood on the passenger side there is a relay fuse box, remove the relay RL20 ( big yellow third one down).
11- Under the hood on the driver side, unplug the air suspension compressor ( big rectangular one).
12- If you disconnected the battery you may need to reset the radio, windows and sunroof.
When you start the vehicle. "EAS MANUAL" will appear on your message display. It will only come on momentarily after start up.
Once you have the jumpers made, the whole entire process should only take about 30 minutes to complete.
Good Luck
 EAS DIY Bipass Harness for Spring Conversions
